Hello all, I've got a Domino that has seen very very little use even though I acquired it right when they came out and had the discount. (why they thought they had to offer a deal to get people to buy this is beyond me!)
The quickest way to explain the problem is that if I put a mortise into the side of a board then flip the board so it is "upside down" and put another mortise right beside it I end up with a very slight V shape instead of an elongated horizontal mortise. The mortises are off a little bit vertically because of the difference in the thickness of the wood. At first I thought it might be the surface I was working on so I used the handle to put the mortises in from the top of the wood instead of placing the Domino on the MFT and got the same result. I haven't cranked on the bit when changing them out. I know that was/is an issue. The Domino has not been abused in anyway, no drops or dropping things on it. I haven't put together more than a hundred joints with the thing and now I'm getting this.
It really becomes an issue when trying to use a single mortise to make a perpendicular angle between two boards. The butt end turns out looking like I need to whip out my 60 1/2 Stanley and do some major adjustments.
I tried searching old posts but got back 100s of hits that I don't quite have time to sift through them all. Putting Domino and Horizontal in the search box and wow do you get a lot of hits because of the alignment issues of the pins, plastic, and lines that people have had issues with the Domino.
Any help is greatly appreciated!
CSM
CSM
