P PerHelgeland Member Joined Oct 23, 2024 Messages 1 Oct 23, 2024 #1 How to set up the domino tool to use it on a 13 mm plate
S squall_line Member Joined Feb 17, 2021 Messages 2,927 Location Eastern IA, USA Oct 23, 2024 #2 Using 4mm dominos, here are a few good resources: https://www.festoolownersgroup.com/festool-tools-accessories/domino-500-and-thin-stock/ https://www.festoolownersgroup.com/festool-how-to/how-to-use-domino-with-4mm-cutter-12'-stock/
C ChuckM Member Joined Sep 7, 2015 Messages 5,743 Oct 23, 2024 #3 Are you using hardwood? If so and if the joinery strength requires longer dominoes, you can go with the 5mm tenons.
