rmhinden
I am learning how to use my new XL 700, and like it a lot. The Seneca Domi-Shim kit makes using imperial sized wood a lot easier. I have a question about domino sizes.
From what I can tell the conventional wisdom is that one should use a 4mm domino on 1/2" plywood and a 6mm domino on 3/4" plywood. Holding the domino up to the plywood, it seems to me that 5mm and 8mm dominos will also work. I have been using marine plywood that is very close to the actual 1/2" and 3/4" sizes. Baltic birch is thinner, but even this appears to work with the 5mm and 8mm dominos.
Is there a downside to using these larger domino? What are others experience?
I also note that sipo only goes down to 5mm.
Thanks in advance.
Thanks in advance.
