With most of the rest of my D select pine stock I made a second less-whimsical table (see the "Whimsical beginning-woodworker practice table" thread). The most interesting part for me was making home-brew table buttons out of off-cuts and Domino tenons. See below.
I made these in a batch by cutting a series of through-mortise holes along the top of a leftover board, after which I rip-cut to thickness and then cut to length with my TS/55. I eased the edges with a block plane.
Installation was on previously-finished parts, so I marked where I wanted each hold-down block on the table aprons, sanded off the finish there, and glued the blocks flush with the top apron surface. Then I put the table frame on the top (flipped over), marked where the corresponding blocks would go and sanded off the finish in those areas. Finally, I glued the tenons into the blocks along the table aprons, slipped the remaining mortised blocks over the tenons, and glued those blocks to the table top, clamping with an ad hoc bridge. One of the tenons running parallel to the grain is glued to both mortised blocks to pin the table top.
This structure could also be implemented with mortises placed directly in the table apron. But, um, for small tables that only works if you plan ahead and haven't glued the table base up before planning fully how to attach the top.
[attachthumb=1]
[attachthumb=2]
[attachthumb=1]
[attachthumb=2]
