Greetings all,
I have a new Domino jointer that I bought for a production job and I need to cut 400 joints.
I am having trouble in that none of the beech tenons fit the mortise, regardless of which size tenon I use. I have the full set of tenons and cutters and none of the tenons fit.
The issue is not so much with the thickness of each tenon, it's the width of the tenon that is too wide. And by too wide I mean that you need to use a hammer to install them (we're talking about extreme press fit here...)
I know that there are 3 setting for the tenon width, but I need to use the narrowest setting so that I get the joints on different parts to line up; so this isn't about just simply using the 2 wider settings.
I believe that there are two possible problems; either I have a bad supply of tenons in every size or the width of the cut is not properly set up from the factory.
Does anyone know if there is a way to adjust the default setting how wide each mortise is cut?
Thank you,
DNRDHS77
Thank you,
DNRDHS77
