I tried searching for a similar topic but came up empty....looking for some help with the Domino XL connectors for joining side rails to post for a bed. The problem I'm having is the fit of the connectors into the mortises. I bought the Festool 203420 Domino XL Corner Joint Connector Set, 32-Pack. Reading through the instructions it indicates that on a standard corner setup all the mortise are bored with the narrow setting...
Problem 1: I cannot make the horizontal pieces (neither the anchor connector into which the post/bolt threads nor the bolt with the plastic cover attached) fit into the narrow mortise. If cut on the wide setting, I can make the anchor fit with a significant amount of pounding which leaves the wood marred... but I still can't get the bolt with the plastic cover to slide into the rail mortise so that the bolt can engage the transverse connector and be pulled tight.
Problem 2: The transverse mortise is too narrow for the transverse anchor such that again if I want it to fit I have to drill the original mortise at 40mm as indicated and then a second mortise with the fence set at 38mm and even then I have to pound the connector in hard enough that it caused the top of the horizontal mortise in the rail to collapse.
In the videos I've watched, the horizontal connectors require some tapping in but not the force I was using. The transverse anchors appear to be started with finger pressure only and then tapped home. Did I just get a set of connectors that were are out of spec (odd that all of them seem to be this same way) or have other experienced the same thing? Am I just missing something obvious?
Thanks!
Thanks!
