Dominofix boring
Moses45
I am ordering 1400 eq router today. To bore material to make my own MFT top I need a 20mm boring bit, a mandrel and what else? I will be using a DOMINOFIX. I have searched here and elsewhere and cannot find anything that lists needed accessories.
The centering mandrel is needed to use a copyring on the OF 1010, on the OF 1400 it is not needed.
So you'll only need the 30 mm copyring for the OF1400.
Moses45 said:
Thanks Frank.
Hi Moses! Exactly what frank says! On the 1400 it has a self centering mechanism. You only need the 30mm copy ring for the 1400 then. If you have any questions, just give a shout!
