Domiplate
waltwood
Maybe I am not posting in the correct forum but I would like to know more about the Domiplate from those who use it. I have seen the video and think it would be good for what I do which is mainly make ply cases out of 3/4" wood core ply. Is using the domino upside down awkward/ hard to get used to?
What are the negatives. I don't have that tool that you take the handle off of to put on it but I guess I could get one from Festool. Don't want to buy a tool I will not use.  Thanks.
Walt
I use a Domiplate on my 500 Festool all the time for work with 3/4" and 1/2" plywood. It turns a great tool into an even better tool. You get perfectly centered mortises every time with no set-up and no fence creep.
I don't find using the Domino upside down awkward at all. You do have to be aware that the oscillating mechanism is somewhat exposed.
I find that threading the Domiplate onto the Domiplate onto the Domino has to be done carefully. I put a drop of oil onto the Domiplate's threads to avoid cross threading.
I recommend practicing on some scrap as there is a lot of technique involved in using the Domino. I apply about 80% downward pressure on the Domiplate and about 20% on the Domino and feed at a moderate rate. In other words, don't slam it into the wood. I cut one side with exact size mortises and the next wider mortise on the other side to allow for side-to-side adjustments on glue-up.
Hi I also have the Domiplates for both my 500 & 700 and  have no issues that are easy to use , it' s a no brainer actually.
It  just uses a set reference  to the centre , they are well made in solid aluminium plate and working upside down is no issue whilst I use mine on my Vac Sys pads which helps Ican see no problems, beside they are cheap if you live in the US I imported mine to Australia which makes everything much more expensive.
I use the domiplate for almost all of my cuts (I have the 500). I get accurate cuts every time - I highly recommend it. It takes less than 30 seconds to swap from 1/2" to 3/4".
I also bought an extra Allen wrench to tighten down the plates.  I use it on an XL with the Seneca cutter adapter and 6mm cutter.
I also have the XL plate. I love the domishims and the only mod I would make would be to build some sort of cams where you mount them to the fence to speed up the mounting/dismounting process.
By the way, on the XL, you still keep the Domino fence on the reference surface and upright. Not upside down like the 500.
Domiplate is super helpful. I can't think of any negatives about it. It a must have. Guarantee you'll love it. I believe handle is supplied with it.
The Domiplate is one of my favorite accessories. The benefits are very quick changeover when dealing with different wood thicknesses, and the rock solid support it provides. This is very helpful when dealing with large pieces where you are working at odd angles and positions. The Domiplate is so solid (literally) that I can push as hard as I want without worrying about fence creep. In these situations, I always use the handle on the plate.
The only drawback occurred when I first stated using the upside down position was the fact that I couldn't see the power switch to turn the Domino off after the cut. I have since gotten used to it, and it is not a problem anymore.
I do a lot of work with complex 1/2" plywood speaker cases. The dominos make it so much easier when trying to align and attach the last side of the box.
I'm attaching a pic of the case showing the 4mm domino holes drilled just prior to attaching the side.
[attachimg=#]
[attachimg=#]
[attachimg=#]
[attachimg=#]
Just Curious, Is that a speaker cabinet?
folded bass horn assembly
Nice Job
I'm doing a set of THT low profile bass horns  later this summer & i plan on using my Domiplate  also .
BTW what design of horn is that ?
