I am finally starting to play with the Domino and am having a hard time wrapping my head around a couple of concepts.
First, I am using actual 18mm baltic birch.
I don't see a setting on the depth stop for 18mm, it has 16 and 20mm.
What do you guys use? or do you have an offset?
What workflow do you use for reference surfaces?
I was making a few drawers that already had a spot routed for the bottom, and was having a hard time figuring out the direction of the reference surface to go from.
I wound up with a couple of boards where I used the wrong face and either did the dominos offset and had the boards not sit flush at the joint, or I didn't do the mortise in the same spots and since I had to flip the board to get the right face in place the mortises didn't line up.
I know there is a better way and it is just a matter of learning the right workflow.
So what do you guys do?
Lastly, I'm using the 5mmx30 domino. I had started to do the plunge depth of of 12mm and 20mm so that I would have a decent amount of space between the end of the mortise and the outside of the board.
I was reading that some people are using 15 and 15 so that they don't have to reset things for each piece.
Is 3mm really enough room for there to not be swelling or telegraphing?
Appreciate the input.
Best,
Todd
Best,
Todd
