Don't you just hate it when you forget the sandpaper
Steve1
Southwestern Ontario
I was sanding a night-table backplate yesterday, and finished up with the 180 grit and ready for the next grit.
So I pull off the sander, turn it over, and see I forgot the sanding disk. Ohhhh.
Just had to vent.
I never had that issue, but I've seen someone ruin a RS400 pad that way..
It's always fun when I take my TS 55 to a remote location and forget to toss the cord in the Systainer.
I only have 2 of the thicker gauge cords -- TS 55 and OF 1400 -- and both are permanently attached to my CT's making it easy to forget them.
As an inhabitant of 230V land (one thin Plug-It cord to rule them all), I feel sorry for your troubles :D
I keep a heavy cord with each vac but one day I decided to travel light and just use the bag on saw’s dust port.
When this happened was the day I resolved to buy a smart phone. When I discovered my mistake my assistant asked me what exactly the thing was called then proceeded to mess around with his smart phone and about a minute he had found one at a lumber yard within bike riding distance. About twenty minutes later I was back in business.
You're just going to have to upgrade to the TS 60. Can't see any other way around it.
I have never done the sandpaper mistake myself, but that doesn't mean there hasn't been a screw up or two.
I learned the hard way, on the DF500, that you cut all of the shallower mortices first. Then when you go to the deeper parts, you're safe. Of course you don't always have off set Dominos, but when you do, that deeper plunge will go right through the side. Been there, which is why I always adjust it back to 20mm height and 20mm depth, before returing it to the Systainer. (That is my most frequent setting)
I do the same with my 18ga brad nailer. I never put it away with nails in it. When I first started, in the cabinet shop, 1 1/4" was the most common size. You only need to leave some 2" nails in it once......
I have also had multiple trim routers out and in use, at the same time. Carelessly picking up the wrong one, and destroying something you have spent hours on......yeah. That is one of the reasons I have multiple brands of trim routers.
Mt first (and only) experience with this was before I knew that there was a difference. I went to my daughter's house for some remodel work, that I had been working on, with the lighter cord.
I went back to the shop and sorted them all out, never did it again.
I’m the opposite, unless the tool will not fit in the Systainer, the cord never gets removed.
Mine never get removed from the CT. I have so many of the cables, in that lower drawer, that I actually sold one of each, to a member here a year or so ago.
That will solve the loose cable, in the low-voltage countries, until some jerk does a work around on that too.... :LOL:
It doesn't help the high voltage guys at all, except totally forgetting to bring one.
That is what I call a one-and-done-mistake. It is a mistake you will make once, but having done so the result is so impactful, that is is highly unlikely that you will repeat it.
I did that same one with my P-C orbital sander. I am clearly not alone as they sell kits to replace the Velcro pads that are destroyed in the process. Replacing the pad is tedious enough and memorable enough that I always remember to check before using.
Another one-and-done-mistake I made was having the very tip of my finger on the wrong side of the cutting edge of my straight edge. Lopped off the fleshy part of my pointer finger on my left hand (subordinate hand). It took weeks to heal. I always take a quick peek before making the cut—though I might not anymore because I bought a safety straight edge. I might have become careless again.
Similar to the below, but mine has a stainless steel rod (about 0.100” diameter) inset into the cutting side of the flat edge. It keeps my utility knife from accidentally cutting into the soft aluminum. If you cut mat board with a utility knife, this is a good investment. When I bought mine in 1980 or so, there was only one maker that I was aware of . Now there are many. I don’t know if anyone is still making them with the stainless steel edge, but if available, a worth while improvement.
I would be interested in other people’s one-and-done-mistakes.
This one has a different approach but addresses the same issue with a flat stainless steel strip at the cutting edge.
This image shows how it is safer:
I think you underestimate the resolve of some us here! ;-)
