I've been asked to make an outside door for a home.
The existing door is frame and panel 40mm thick and the client has noticed condensation will gather on the panels machined outer edges.
Due to them being thinner I think.
Does anyone know any other concepts on door design that could avoid this condensation?
I think some off the manufactured doors are engineered "solid" with laminated layers glued and pressed together in huge machines. Hence they have stability to prevent movement!
Between 0.35 and 0.51 seconds it shows a few doors with what looks like a "plank" design inside a frame.
How is movement catered for?
