So I've finally begun building the drawers under our stairs and now that I'm finalizing the drawer sizes I bumped into and interesting question.
The slider dimensioning guide very nicely mentions that the slider requires 12.7mm of space and should be mounted near the centre line of the drawer side... but it doesn't give any indication on how much space/tolerance should there be to the runners.
What I mean is that since the staircase has a width of 848mm should I design the drawer to be exactly 848mm wide with slider hardware installed or should I leave some tolerance for the possibility of a non-ideal staircase?
Common sense would say to leave a mm or two on each side just in case, but then the engineer in me wants to do exact dimensions... (I'm using Accuride 3832 SC's as sliders)
