Dropped my DF500! Need help
Guys, dropped DF500 from MFT. I can no longer adjust/tighten the fence with the two locking levers.
Not sure if this is something people have come across before. Hopefully it's something that can be fixed with an adjustment - I just can't quite figure out how to do it.
Going to download the DF500 guide/troubleshoot but thought I'd post this in the meantime.
Here is a brief video explaining the problem:https://1drv.ms/v/s!AjGM74qML95XgP4FI76Gd0mnC6wcfA
Any and all advice appreciated
Vondawg said:
How about.........
Have you tried removing the Philips screw(s) and re-positioning the handle(s) it looks like a mark on it...like, that's where it hit
I don't think it hit where the mark is, I think that's just glue and should clean up. The strange thing is that both of the levers no longer tighten the fence so I didn't think removing the philips screws would make a difference. Also, I wasn't convinced that there is the possibility of repositioning the handles with that screw, although I could be wrong.
Both of those levers are mounted on a Hex shaped shaft. Just remove each one and move the lever round one notch and see if they will tighten up then.
I cant quite see how both levers would have been affected by the fall though...???
Ok, I'm trying to do that but how do I remove the lever once i've removed the philips screw? Should the levers pull off? I'm afraid to use too much force, they aren't budging
Right, so the lever unscrews all the way out with the threaded bolt attached.
Based on the advice above, I think i need to remove the black plastic lever from the threaded bolt, and reattach it after a full turn. But i cant see how this is possible
I have no idea how the drop could have caused this!
I just checked on my own DF500 Domino machine and the Phillips screws just unscrew leaving the levers in place. Then, pull the lever off completely, rotate it backwards 1 notch of the hex, refit it, refit the screw and the lever should tighten up.
THANK YOU!!
That worked, really appreciate your help
