teton176
- Mar 4, 2025
Howdy folks:
I'm forked on a project and am inquiring if you folks think a DTS 400 might be the solution.
The project is repainting my kitchen cabinets. They are structurally sound (rock maple doors , 3/4" plywood frames) but the finish has failed. Badly. I'm in the process of stripping and sanding the doors and the RTS 400 + CT 26 are kicking @ss on the flat surfaces. The problem lies with the cabinet profiles as there is a lot of detail work to be done. I mean, A LOT. I'm using various grit sheets on the flat surfaces and the Uneeda foam-backed pads on the profiles, however, the Uneeda pads just aren't getting into the nooks, crannies and corners.
I have money to spend on a DTS 400 if that is the answer. Any input would be welcome. Thanks!
