Birdhunter
- Jun 16, 2012
I am building a dresser that has 6 large drawers each 30" by 18". The drawer sides are 8' high and have a 1/4" strip of oak on top. The drawer sides are sanded and ready to finish with MinWax Wipe-On Poly. I didn't sand the Baltic birch bottoms thinking I'd remove them for sanding once the drawers and slides were fitted.
The drawer slide fitting was much fussier than I believed it would be! Now that all 6 drawers fit, the last thing I want to do is take them apart.
I need to lightly sand the bottoms with them in place.
I'm thinking of buying a DTS sander, either the corded or the battery model. I have a RO90 so could use it in the corners as I would the DTS. I tend to get scratch marks with the triangle on the RO90 even with the vac turned way down.
Is the DTS the right sander and should I go battery or corded?
