ben_r_
- Oct 13, 2015
So Im considering adding a DTS 400 REQ to the collection and thought I remembered reading that with the RE versions, specifically the RTS 400 RE the sanding platen / pad could be swapped from the rectangular one for the delta one from the DTS 400 RE. Is that still true with the new REQ versions? And if so can either use the others sanding pad? Or is it just one can use both and not the other. And what are the part numbers for the pads for the REQ versions?
Whichever route I go I would love the ability to use both the Delta and the Rectangular pads if thats still an option in the REQ versions.
