Duplex LS 130 - Linear Sander
boisetmetal
hello,
This new video is to show my last tool ! Festool  hé hé !
So this is the Duplex and I like this tool ! There is just few video about this Duplex !
So now this new video can show you, when you desire good finish, that this tool can give you good result !
You will find this new video here : DUPLEX LS 130
eric
I chucked when you tried to keep the RO90 straight on the edge of the board. You did better at it than I probably would. Generally when I have to do this or want to run them through my SuperMax, I clamp them together to give myself a wider surface on which to rest the sander.
Naturally the LS130 won't leave swirl marks, but I was kind of surprised at how nice the finish from the RO90 was. I was listening with the sound off - so perhaps you said - but was the RO90 in Rotex or Randon Orbit mode?  You may have forced me to consider the LS130 as a future addition to the stable. - dang you!
[wink] [big grin] [poke]
he position sanding of RO 90 was finishing position.
But as I say in the video would have been better to sand having moved the clamp. This enables them to see the work that the Rotex 90.
Sand one end side with the Rotex requires good hold and that's the difference with the LS 130 in which the force front / rear, but nothing in side!
In fact I needed a sander capable of working on some large area of moldings, and small parts! And if after buying the Rotex 150, I switched to the 90 which is already much softer, the Duplex is even better!
