Dust Deputy Cart
Drich
hello
With the tool Nut having the dust deputy on sale and picking up a new new shop vac from lowes ( black Friday deal) I'm wanting to build a nice cart for them. I will be using this set up for the Kapex mostly and the router table as the CT 36 will be for the MFT table. I do see this cart set up out on the web in many places. Just wondering if someone has something better. Thanks
http://www.makermasters.com/diy-cnc-project-dust-deputy-cyclone-separator-cart
Also does it matter how large of drum you use? Would like to go bigger that a 5 gallon bucket for when i use the 12 inch planner I have. Found a nice 14 gallon Plastic one with a locking lid. Will that affect the suction power ?
Its not a problem being on a bigger drum. I have mine on a 20 gallon drum, its works great. like rvieceli said just make sure side wall and top of drum are strong enough.
If you put a plastice trash bag in, use your vac to draw out the air between drum and bag.  I cup my hand against the drum sides and put the vac end in the hollow.  With a little practice you can get the bag to grip like yoga pants [wink]
Thank you for the how to on the bag install. Did you make a cart for the set up? would like to see it. I have a few ideas on how i want to make it. Also did you have to beef up the lid for the drum to support the dust deputy.
I did see a few peoples carts where the put the vac up high so the hose is short to the inlet of the cyclone. I did like that idea. With a 14 gallon drum it might put the vac kind of high in the air. Any thoughts on that? It might save on space that way.
