ear3
- Jul 24, 2014
Just started using the 1010 for some edge profiling tasks where I had to ride along a narrow surface. Worked fantastically, even with a 1 1/2" diameter bearing guided bit mounted, which is slightly above the max specs (and which everyone said, quite correctly, would not be a problem).
There's an issue with dust extraction, however, since the diameter of the bit exceeded that of the chip catcher. So there was quite a bit of dust without the shield over the bit. I was flipping through the OF1010 accessories page to see if there was some other accessory/solution to assist with DE in these situations, but I didn't see anything. Am I missing something? Or, failing an accessory, is there a DIY way to cut down on the dust when edge routing with large diameter bits? Thanks.
