DW735 Worthy Earmuffs – or other ideas for toning down the screaming banshee?
dlu
Turned on the new DW735 for the first time – and turned it right back off. It is hands down the most unpleasant power tool I have ever been around. Two questions:
  • First - suggestions for some really good earmuff type hearing protectors? The ones I have are old (close to 20 years I think) and don't cut it with the 735. Hoping that there is something newer and better out there.
  • Second - besides a Byrd head, is there anything that can be done to tone it down? I definitely see a Byrd head in my future.
Wait till you run a 12" piece of maple thru it..... Your filings will rattle...  I use foam ear plugs AND headphones when using mine....  Although, after running 1000s of bf of hardwood thru it it stopped raising and lowering. So I went out and bought a PC 12" in a pinch to get a job done and the 735 sits under a pile of dust cause is too heavy to move around. I hope they fixed the thermal overload issue with the switch as well..... Cuts out more and more the longer you use it. There's a simple bypass you can make and is never an issue. Also, run it on as short a lead as possible. On a circuit as close to the panel as possible.... They are juice hungry machines and don't like iffy jobsite power situations for long.....
The "3M™ PELTOR™ Optime™ 105 Earmuffs H10A" have the highest noise reduction (30dB) that I have been able to find. Combined with a helical head and you will be happy.
Believe or not the 735 is quieter than some including the previous DW's.
A factor that also might be contributing is that at 20 + years the spring and thus the tightness of seal might be wearing out on the pair you have.
I also use the 3M Peltor that are linked above. Very good.
