- Oct 16, 2015
This may sound odd, but to me the shape of the body of the ETS and RTS look the same, at least up around the area of the clamp. Has anyone tried to use this with an RTS?
Crazyraceguy said:This may sound odd, but to me the shape of the body of the ETS and RTS look the same, at least up around the area of the clamp. Has anyone tried to use this with an RTS?
The edge guide is adjustable 43 - 92° per the spec.Packard said:All these sanders seem to edge sand at a 90 degree angle. I have found that a slight bevel reduces the chance of the banding coming loose or catching on something. I trim using a 2” wide chisel and finish with a sanding block at about 20 degrees.
woodferret said:Stumbled across some new uploads for the RO150 and ETS EC125 90-degree edge guides.
https://www.thingiverse.com/thing:5513969https://www.thingiverse.com/thing:5703402
