R Rockhigh Member Joined Oct 11, 2020 Messages 20 Jun 12, 2021 #1 It drives me crazy that every time I remove it from my sander I misplace my bolts. So quick fix is to add a couple of o rings on the bolts. Solved my problem and thought I would share. Sent from my iPhone using Tapatalk
C CeeJay Member Joined Feb 18, 2020 Messages 437 Jun 12, 2021 #2 Good hack! Sent from my iPhone using Tapatalk
C ChuckS Member Joined Sep 7, 2015 Messages 6,033 Jun 16, 2021 #3 Don't you have to remove the o-rings before mounting the edge guide? If so, how you keep track of the o-rings? I keep the bolts and allan wrench together with a magnet. Attachments 20210616_204550.jpg 469.1 KB · Views: 452
R Rockhigh Member Joined Oct 11, 2020 Messages 20 Jun 17, 2021 #4 ChuckM said: Don't you have to remove the o-rings before mounting the edge guide? If so, how you keep track of the o-rings? I keep the bolts and allan wrench together with a magnet. Click to expand... Nope, just leave o rings on bolts and tighten up (they squeeze down) then bolts stay in one side of edge guide when I disassemble
J johnyhuh Member Joined Feb 7, 2019 Messages 78 Dec 27, 2021 #6 Perfect hack! Exactly what I needed. Thank you!
Crazyraceguy Festool Moderator Festool Moderator Member Joined Oct 16, 2015 Messages 5,739 Dec 28, 2021 #7 That's essentially how the extension foot works on the Domino machines too.
