Hi everyone,
Need some advice on edgebanding. I am deciding how thick i should edge and my shelves and not sure if i can do this based on my tools. I have both an MFK700 and an OF1400. I was planning to trim the front of my double thickness shelves with poplar before painting. My question is, should i bother with poplar at all, or stick with "thicker" edgebanding and use the MFK700 to trim. I know there is a thickness limit for the MFK700 horizontally. Alternatively, if i was to use a thicker edge with popular and make the pieces overhang the double-stack shelves i would need to surface the edge. In the vertical position, can i use the MFK700 to "surface". i.e. bring the poplar down to the same surface as the shelf?
Both options will be painted. Not sure if i am just overthinking this!
