EmmaMerie's Jewelry Box
stvrowe
This jewelry box is for my 6 year old grandaughter and is made of cherry, cocobola, and purpleheart.  I referenced the plan in Woodsmith issue 112 but pretty much changed everything (including dimensions and construction) except for the 3 way miter details.  I made these changes primarily to lighten the box and make it less bulky looking as well as match my preferred construction methods.  I used cutoffs and leftover materials from other projects that were too small to be useful in other larger furniture projects.  The hinges are Brusso JB-102.  The interior finish is a wipe on gel varnish, the exterior is garnet shellac and paste wax (more on that later  [crying])
Festools used during the construction are:  Domino with 4mm dominos, ETS-150/3, and RO-90
I am happy with the results and did learn a few lessons.  This was my first use of cocobola and I knew enough to wipe the cocobola with laquer thinner to remove oils for gluing.  I was not aware that these oils would also inhibit the curing of oil based finishes.  After several days, the finish was still tacky around the edges so, I then referred to Bob Flexner's book Understanding Wood Finishing (an excellent resource by the way, but only if you read it first ::)).  Based on the recommendations in the book, I tried warming with a heat gun which was an excercise in futility so, I built a small box out of styrofoam insulation and placed the box with a drop light in it for about 8 hours.  The temperature stabilized at around 120F and I honestly think the finish felt even more tacky when warm.  I then decided to strip the finish and sand it again.  This time, I would follow the books recommendation and wipe the box with laquer thinner (did it twice for good measure) and then re-apply the finish.  This seemed to improve the situation but still after 3 days of curing (or not curing), the cocobola still felt tacky. [crying] [crying]  So - strip and sand again.  Now, I really like Festool sanders but, not this much [big grin].  It was then off to the shellac route which worked extremely well.  ;D ;D ;D
Now to the second lesson learned.  Last step is installing the brass hardware with, you guessed it - brass screws.  I did not have a steel screw the same size so took extreme caution and pre-lubed the screws with beeswax.  The 3rd screw was almost fully seated and the head breaks off [crying].  Tryed backing it out with a pair of pliers and it snaps off flush with the wood surface [crying] [crying].  With extraction being impossible at this point, I decided to mill it out, so chucked up a 3/32" carbide mill in the drill press, clamped the box lid down and it was working very well.  And then, snap, now I had a carbide mill buried where a screw need to go  [crying] [crying] [crying].  Tried fishing it out but this puppy was staying put.  I ended up drilling an adjacent hole and using small chisels, excavated to get the carbide mill and remnants of the brass screw out.  I was then able to clean it up and glue in a plug.  Used the next larger size drill and finished installing the hardware. [big grin]
I am not sure I want to risk touching this again but, I am thinking of installing a knob on the lid.  What do you guys think?  I don't know how to do a poll so just post suggestions.  I am thinking:
a) Leave as is - no knob
b) Small brass knob
c) Turned cocobola or ebony knob
d) Sculpted small handle of cocobola or ebony
By the way, this is a Christmas present so, if you know a little girl named EmmaMerie - shhhh!
Steve:
I vote for no knob.
Unless you are loading that up with a bunch of gold, it's really a toss up if a knob will be used to open it.
Looks good BTW.
Tim
Great piece and thanks for sharing the lessons learned!
I think it looks, and should work, fine without the knob.
I'll bet she will love it.
BTW, I agree those brass screws are a Beeach! They shear way to quickly.
That box is nice... I would not recommend a knob, but rather use a cove bit to dig a space for the finger to be able to gain purchase on the lid and pull it up.  Put the lid tight against a router fence, put a stop on each side and dig away.  Believe it or not, your baby is going to grow up and we would not want to have her ruin her nails getting the lid up, would we?
No knob it is.  I was leaning that way anyway, you guys just confirmed it.
Thanks,
Steve
Very nice. I really like the look of trimming all the edges  [cool]
