Emtech 9300 + CL100 crosslinker
I'll be spraying 8 walnut table tops for a restaurant within the week. Using a Fuji T75G gun/PPS cup, Target Coatings Emtech 9300 and the CL100 crosslinker. The coating appears to be a very good choice for high use/heavy cleaning table surfaces in more commercial settings.
Application looks to be straightforward. I'll update with my experience later on.
Curious if anyone has used this combo before? Were you pleased with the final results?
I have not but am interested in your results.  Please post with your thoughts on that combination as well...
Thanks,
Trevin
The EM9300 sprays nice for me when thinned with least at 5% with water. Be careful with the crosslinker and make sure its fresh. Its given me a finish that was like sandpaper. The finish typically gives walnut a lifeless look when used on its own because it clear. You may want to do a few test pieces to make sure its what you are looking for, some like this look. it will be interesting to see how it holds up to restaurant abuse especially on a soft hardwood like Walnut.
