guddeco
- Jul 2, 2014
I am having issues with my ETS EC 125/3. I purchased the new brushless 125 late last year as a replacement for my older ETS 125. I use this sander almost daily, so I'm certain I've surpassed the break-in period. I've owned it for several months. I am having a strange issue with the EC that I never saw with my older 125. I'm getting surface scratches that are clearly visible. Now, I understand that's what an orbital sander does, but my scratches never go away no matter what I've tried. I don't know if it's user error, or if my sander has a problem. I ran my older ETS 125 on the lowest suction setting and just floated it on the surface for really great results. This one didn't perform well on the lowest suction setting so I've tried multiple solutions with no real good solution. I have it hooked up to my CT36 and have tried more suction all the way up to 3/4, and all the way down to the lowest. I get better results at 0-1/4 suction, but I still see the scratches. I've tried more pressure, less pressure, floating the sander while holding the vac hose on the back so my hand isn't adding any pressure to the top., no pressure but my hand guiding the top, to really no great solution that I can repeat. The only way I can get them to go finer and finer is with brand new sandpaper each grit. I never had to do that with my ETS, which leads me to believe I may have a faulty EC 125. I'm including pictures of my scratches in hopes to find a solution, or to have it recommended for Festool to look at it. The abrasive progression for these photos were, 100, 150, 220, 320 with the photo being taken after the 320. I'm just quite frustrated that I am left wanting my old ETS 125 back. Please help!
