Ets ec 150 to midi extractor connection
The hose from the CT MIDI will simply press fit over the output connector from your 150 (I was just using mine last night!). It's a tight friction fit so you just gotta wrangle it and twist it on. Then be sure to adjust your vacuum (reduce it) to allow the sander to "glide" over your sanding surface.
