My ETS150/3 EQ has been serving me very well for about 10 (?) years. I did need to replace the electrical socket (connection plug) at the tail end a few months ago. Other than that, it has been working fine.
During a sanding session this morning, the tool decided to not work at all. It had worked for about an hour. I took an hour break to do something else. When I started again it worked for about 5-10 minutes then would not work at all.
I checked power to the tool: good. I opened the case and checked power on both sides of the switch: good. I checked power on the circuit board: good. I checked power to the brushes: that appears to be good as well. All of the readings were about 118 VAC.
My best guess is that it needs brush replacements.
Now, this is where I am having trouble. The exploded diagram that I can find online shows Diagram Part #9 as two Brush Holders. These are part # 491363 and appear to be sold as a set of two.
Do the brushes come with the Brush Holder Set? Or, do I have to find them somewhere else? I do not see the brushes on the exploded diagram.
I need to get operational again quickly. I do not want to order the Brush Holder Set then find out (days from now) that there are no brushes in them. [eek]
Any ideas, please?
Any ideas, please?
