Exotic Hardwood Deck
roblg3
Basically a deck "resurfacing"
Wood species: Goncalo Alves, "Tigerwood", "Jobillo"
Janka score: 2170
The customer chose the wood and a basic design focused on a central "V".  Previous surface PT 2X material with solid body stain.
Challenges: Out of square, level framing.  Tigerwood glues terribly because it's so water repellent.
I use mostly Festools: Miter, Circular, Router, Impact, Drill, Domino, Sanders, DE, Jigsaw....
3 Photos of original deck with more to follow
After demo The angle needed to be refigured because there was over 32" of run between supporting joists.  Using 2 16" boards i was able to decrease that angle to 100 degrees and achieve 18" between supports.
I cut all the boards from long to short to be achieve the beginning piece length.  My original idea was to domino and glue the ends making a tight joint like I have with IPE before.  This wood does not glue well at all and the joints failed.( fix shown later)
Second oops detected...luckily a quick redesign and customer approval created a nice detail.  I turned the too short boards 90 degrees to the V and used loose Sipo Dominoes for end support .
The wood looks great when wet~!
Great job! The homeowners will certainly be showing off this deck so referrals will follow. [big grin]
Great job.  What are you gonna finish it with.  For exotics, I really like the super deck line.  It's a penetrating oil.  I do a lot of braz cherry deck using it.  Every year it simply gets a refresher.  Keeps everything really nice and protected. Very clean look
There's no plans for any finish. When rained on for days, on the very surface gets wet.  Water does not penetrate the long grain.  All ends sealed with log sealer.  I convinced the homeowners to scrap the arches on the pergolas for a more consistent Japanese gate style.
I'd just worry about the deck fading faster without any type of finish on it and needing to be resanded more often.
I would add a penetrating oil.  Penofin makes a product for exotic wood.  Warner is correct it will be silver grey in 6 months.
It's not a bad thing,  I did two large Ipe decks this year and they wanted them to silver out.
I think they look good silver too.
Tigerwood has given me the most trouble out of all of them.
The nice thing about these exotic hardwood decks is after the silver out if you decide to restore it someday it's not that difficult.  Keeping in mine that some-annual or more maintenance is going to be required or you'll go back to silver.  I can never get miters to stay tight with these woods with Red Balau being one of the worst for me.
The neat thing about this wood is that it DARKENS over time turning more red and DOESN'T silver.  I've not had trouble in the past keeping Ipe miters together.  I dunno maybe the dominos, glue and blind screwing make them stay together??  I've jointed lots of hardwood for exterior projects.  Maybe the care I take to wipe the oily wood with acetone and then moisten the end grain before glue-up makes the difference.
Oh, it turns silver give it a year.  I have done everything to miters, dominos, acetone wipe, epoxy, pocket screws, extra screws and plugs, etc.  They will open up.
thought i should update this
more photos
Very neat work, bit dark for my liking but looks brilliant none the less!
You mentioned about tigerwood and ipe being a pain to glue which leads to joints opening, have you tried a pocket screw jig?
better than a domino for that kind of joint in my opinion.
~WW
