Fastfix angle attachment DD-AS problem
Rob-GB
Hi all, the afore mentioned unit has broken.
I was drilling a pilot hole with it and the drill jammed to a stop, if I tap the unit body smartly it works again for a few seconds then stops.
I suspect the gears have partially stripped or something like that.
I will be contacting Festool UK about it but wonder if this is a rare problem or not as the unit has only seen active service 3 or 4 times since new and nothing strenuous.
Any info would be appreciated. Thank you.
Rob.
Rob,
Used the right angle attachment loads of time , never had any problem with it, always taken it to be a substantial heavy duty bit of kit. Used it with  augers and drills and large and small screws. Never heard of any problems reported
John
windmill man said:
Rob,
John
Thanks John, I've used it with a max 8mm festool brad point bit and on small screws fitting cornice to kitchen cabinets so was a bit gobsmacked when it failed. Just wanted some background history before ringing TTS in Morning.
Rob.
Rob, yours is the first report of failure that I read here on the FOG since oct 2008, so I guess this isn't a common problem.
Rob,
I ve used 2" augers through pitch pine joists and put those 12" torx head screws in with mine no problem and it still feels as tight as when it was new,
Cheers guys, guess I was just unlucky [sad]
Gotta try TTS again in a bit.
