Fein w/ Depth-Stop and Plunge Base Set OS-TA/AH Set Item number 500251
diymco
I wanted a high end *CORDED* oscillating tool (this rules out the current offering from festool).  I decided that the Fein Multi max 700 was a good choice.  Does anyone know if it is compatible with the festool "Plunge Base Set OS-TA/AH Set Item number 500251"?
Thanks!
Thanks!
The Festool plunge base (and other quick release accessories) fit my Fein AMM 700 which is the battery version of yours I believe.  Starlock quick connect is unaffected.
Edit: I've realised that the set number you quoted doesn't include the required adapter.  You will need set number 203258.  Sorry for any confusion.
