Festool 493998 Suction Hose Plug It with trend t30?
ldmillar1981
Hi all
I wonder if you can help me i have a rotex 150 feq and a ts55req and i am over the moon with them both the ts55 req with the FS-PA is perfect!, i use them both currently with my trend t30 dust extractor that i have had for many years and i am very happy with. one day when the trend gives up the ghost and i can afford it i would love to get the CTL 26 but for the time being i am wondering if there is any way of fitting the Festool 493998 Suction Hose Plug It D 27/D 30x3,5M-AS GB 110V to my trend t30 so that i can use this hose with my festool tools for the time being and then at a later date use it as intended with the ctl26.
my problem is have the lead and the hose they get tangled and the hose is longer then my plug is so the plug it suction hose seems ideal
Many thanks & Kind Regards
L Millar
Hi Millar welcome to the fog
I use my t30 hose with my ct26 all the time because it is more flexible than the festool 36m hose
and it works the other way as well apart from there is no locking clip on the festool hose
but the festool hose is a good fit on the t30and will not fall out. I have 4 t30's [embarassed]
If you want a new plug it hose give peter or david a call at slingers 1858 they have what you want from stock..
thank you for the info! i will give slingers a call tomorrow.
Do i need any adaptors for the festool hose to fit the ts55? as the festool hose is 27mm?
No nothing else is needed its a direct fit..
