Just for kicks I made a prototype using some 5mm plywood for my PC690 router a couple years ago. It worked but I never bought a piece of aluminum to make a permanent one from. I just use the OF1400 but I wanted to see if it would work.
The shim locks the pin up so you can slide along the rail without engaging a hole every 32mm.
