Joe DArc said:
Before I purchased my boom arm, I toyed with the sleeved hose (shorter version). I purchased some white plastic drain supports (for that corrugated plastic black drain line), from Home Depot, with holes in the arm portion of the hook, to nail them at whatever drop length you wanted from the joists. Then I hung the sleeved hose from those supports. However, without the boom arm (and it's hose and cord extensions), the hose became too short to serve the purpose I wanted. Once on the boom arm, the shorter sleeved hose was perfect for my use (but I just move my
CT26 to the particular workbench I am using).
I briefly considered passing on the boom arm and just get the longer sleeved hose, but as I thought about it, I really did not want all that length hanging from my shop ceiling. Of course, you could just let it drag on the floor, but that creates problems of it's own (tripping).
As for the concept of being worth it, I would say yes if you can work out the location problems. I would not want it on the floor full time, as that sleeve is a light color, and would start looking pretty dirty fast. I also think you need to consider the fact it will prevent you from moving other things around, without needing to lift the hose out of the way.
Also remember it is a tapered hose, ending at 22mm on the tool end, so
basically it is a sander hose, and tools that discharge larger chips won't like it. My solution is to have the larger 36mm hose on standby, for other tools. I simply hang it on the boom arm with my shorter sleeved sander hose, and can use either when needed.
