festool automotive polishes
HowardH
I was looking at the Australian site and noticed some automotive polishes that look very interesting.  i know its a NAINA issue but since UL doesn't have jurisdiction over a polishing compound, I'm wondering why it isn't available here.  It would seem to be a natural to use with my Rotex 150 and fine sponges.  Has anyone used the stuff and can one order it from a non-US site without potentially triggering a trade war or some such provocation?
Why mess with it? You can get the 3M pro polishing compounds for reasonable prices pretty much all over. I've used them in the past when I used to do custom fiberglass work and they work really good.
http://selector.3m.com/selector/us/en/auto_marine_aero/automotive_aftermarkets/aad_p/viewlist.asp?FAM=Rubbing_Compounds&LL=aad&ITEMLIST=3454,3455,3456,3457,3458,3459,3460,3461,3462,3463,3464,3465,3466,3467,3468,3469&P=
No offense to the Festool stuff, but I'm going to bet you can get the same results out of the 3M compounds at a fraction of the price here in the US.
I agree, I detailed cars professionaly for 5 years.  We used a lot of 3M buffing compounds w/ a high speed buffer.  They make great products.
That's good news. Thanks for the heads up!  The rotex does a great job polishing.
Howard,
I agree with all the others here - for whatever reason (enviromental??) they are not available here, but there are so many excellent polishes readably available, you are not at a loss.
Bob
Bob,
That could possibly be the reason the Festool Polishes are not in the states because we already have a lot of extremely good polishing agents.  If Festool can't make the best product, the won't sell it in the states?
-Dave
Bob,
So you use the RO125 to polish your car?  I should try that sometime.  I always used a Makita High speed buffer with variable speed.  It's an awesome buffer and light weight.  Doesn't make your arms tired.  If your like me, If I were to use the RO for buffing my car, I would enjoy a side handle on it.  I've already come into situations where I could have used a side handle on it.  Are there any after market handles or universal handles you can buy to put on the RO125?  I think Festool should have at least put a connection on the RO125 so people could buy the same handle for the RO150 and use it on their RO125.
-Dave
Update:  Bob not Tom =)
ForumMFG said:
Tom,
-Dave
  I don't know about Tom, but I do use the  RO 125 rather than the RO 150. I know there are many other high speed buffers out there, but for me, with the RO's, there's no need to look elsewhere. But I have never felt the need for the side handle for the 125; Ilike the smaller size. I am not sure about any after market handles for the 125.
Bob
I have had many years of buffing new and used cars. Held the record, I think, for the number of burn through ridges on 55/56 Buicks. I finally did learn a light touch. At that time we used Dupont No 7 buffing compound and diluted it with water 1;1. When I started use of Rotex 150 i paid trip to auto stores and brought home one of everything. Polish with compound by 3M or Mothers seemed to be what I was looking for. Have used them both with success but really have to watch the action...still easy to burn through. I had a new car and saved the old for giving away to local church. But before it went bye bye I used it as practise car. I suggest every one do the same -- find an old car to practise on. If youwant the best test, find a black or at least dark car and go at it...you can make it look brand new if not rusted though.
This use of automotive buffer that I used for buffing out mahogany sink top. I used the Beall buffing system and got a mirror perfect top -- that was 9 years ago (before Festool here). I still have the heavy buffer and like the cotton pads it used but Rotex 150 used now.
When I first got Rotex 150 i did a lot of experimenting. My final process that I found and still use today is the Rotex to 22o grit paper and then changing to soft buffing pad and use the Menzerna system:
At that time, we would go through all the Menzerna grades. I since have found that the first Menzerna is too harsh and I start with the second compound. In any case, no matter what you use, apply the compound to the piece manually (old T shirt works fine). Once evenly spread, use the buffer lightly.
These pages have the  whole process. It was done years ago but still works. polishing technique
John,
Did you have any finish, stain or topcoat, on the piece before you buffed?
Les, in the case of the Koa, no it was bare wood to start.
I prefer to use it in a finish "menu"  typically, 1) sandeind sealer, 2 -glossy polyurethane 4 thin coats with light sandingg (400) between; 3) let cure for 5 days; 4) start buffing sequence ( mentioned above)
This gives you a strong durable finish and high gloss. If you dont want hgh gloss, use satin poly finish but only as last coat - that gives you a sheen but stil has the depth of finish as the glossy.
