Festool Cristal Abrasives 30% Off at Tool Nut
Shane Holland
Festool Dealer
While supplies last, Tool Nut has an exclusive offer with all Cristal abrasives at 30% off catalog prices.
A great deal for anyone who primarily needs to sand bare wood or strip finishes/paint, also good for fiberglass, epoxies and plastics. Note: Cristal is only available in grits P40-P120.
Festool's Cristal abrasive stays cool, won't clog and makes short work of tough jobs. Cristal employs a durable aluminum oxide that cuts, rather than grinds, the material surface, leading to faster material removal and a cleaner finish. Cristal employs a flexible bonding material and no-load coating, making it the ideal abrasive solution for rapid material removal, stripping old finishes, or rough shaping. All Festool abrasives are engineered and manufactured to strict FEPA standards, guaranteeing uniform abrasive positioning and consistent sanding results.
Rotex RO 90 / DX 93
Festool 496339 Cristal Abrasives, 93mm, P100 Grit, Pack of 10
Festool 496340 Cristal Abrasives, 93mm, P120 Grit, Pack of 10
Festool 496336 Cristal Abrasives, 93mm, P40 Grit, Pack of 10
Festool 496337 Cristal Abrasives, 93mm, P60 Grit, Pack of 10
Festool 496338 Cristal Abrasives, 93mm, P80 Grit, Pack of 10
DTS 400
Festool 496349 Cristal Abrasives, 100x150mm, P100 Grit, Pack of 10
Festool 496350 Cristal Abrasives, 100x150mm, P120 Grit, Pack of 10
Festool 496347 Cristal Abrasives, 100x150mm, P60 Grit, Pack of 10
Festool 496348 Cristal Abrasives, 100x150mm, P80 Grit, Pack of 10
Festool 496351 Cristal Abrasives, 100x150mm, P40 Grit, Pack of 50
Festool 496354 Cristal Abrasives, 100x150mm, P100 Grit, Pack of 100
RTS 400 / LS 130
Festool 494055 Cristal Abrasives, 80x133mm, P100 Grit, Pack of 10
Festool 494056 Cristal Abrasives, 80x133mm, P120 Grit, Pack of 10
Festool 494052 Cristal Abrasives, 80x133mm, P40 Grit, Pack of 10
Festool 494053 Cristal Abrasives, 80x133mm, P60 Grit, Pack of 10
Festool 494054 Cristal Abrasives, 80x133mm, P80 Grit, Pack of 10
Festool 494058 Cristal Abrasives, 80x133mm, P60 Grit, Pack of 50
Festool 494059 Cristal Abrasives, 80x133mm, P80 Grit, Pack of 50
ETS 125 / Rotex RO 125
Festool 496002 Cristal Abrasives, D125mm, P60 Grit, Pack of 10
Festool 494032 Cristal Abrasives, D125mm, P40 Grit, Pack of 50
ETS 150 / Rotex RO 150
Festool 496599 Cristal Abrasives, D150mm, P100 Grit, Pack of 10
Festool 496600 Cristal Abrasives, D150mm, P120 Grit, Pack of 10
Festool 496597 Cristal Abrasives, D150mm, P60 Grit, Pack of 10
Festool 496598 Cristal Abrasives, D150mm, P80 Grit, Pack of 10
Festool 496601 Cristal Abrasives, D150mm, P40 Grit, Pack of 50
Festool 496603 Cristal Abrasives, D150mm, P80 Grit, Pack of 50
Festool 496604 Cristal Abrasives, D150mm, P100 Grit, Pack of 100
Just a quick bump before we broadcast this more broadly. Wanted to give FOG members the first shot at this deal since some of these have low availability.
I have found that the cristal sanding disk were not lasting long.
I bought a box of 60 grit and found that the granit lasted a lot longer then the cristal.
No comparison at all.
Cristal is faster at paint removal than Granat, it's sharp particles cut like butter through thick layers of old paint.
The backing paper could be of better quality, yeah, they do wear out fast. But I have the same gripe about Granat.
Ditto. I still find Cristal useful for certain tasks.
When I used it it wasn't on paint. It was on poly and wood so maybe that was why.
I will have to try it on paint one day.
Alex, did Festool discontinue Cristal in Europe as well?
I was going to say no, because I still see it in stores and bought a pack 3 weeks ago, but when I check the Festool website it's completely gone. So I guess it's a yes instead. What a bummer.  [sad]
So, we've knocked another 10% off the Cristal prices for anyone who's interested in snagging some paper at a great price. Now at 40% off catalog prices, as low as $0.25/sheet. While supplies last. Some items have very low stock.
Order Festool Cristal Abrasives at 40% Off
$3.60, DX 93 / RO 90 DX Sanders, P100 Grit, 10 Pack
$3.60, DX 93 / RO 90 DX Sanders, P120 Grit, 10 Pack
$3.60, DX 93 / RO 90 DX Sanders, P40 Grit, 10 Pack
$3.60, DX 93 / RO 90 DX Sanders, P60 Grit, 10 Pack
$3.60, DX 93 / RO 90 DX Sanders, P80 Grit, 10 Pack
$4.80, DTS 400 Sander, P100 Grit, 10 Pack
$4.80, DTS 400 Sander, P80 Grit, 10 Pack
$14.40, DTS 400 Sander, P40 Grit, 50 Pack
$4.20, RTS 400 / LS 130 Sanders, P100 Grit, 10 Pack
$4.20, RTS 400 / LS 130 Sanders, P120 Grit, 10 Pack
$4.20, RTS 400 / LS 130 Sanders, P40 Grit, 10 Pack
$4.20, RTS 400 / LS 130 Sanders, P60 Grit, 10 Pack
$4.20, RTS 400 / LS 130 Sanders, P80 Grit, 10 Pack
$12.60, RTS 400 / LS 130 Sanders, P60 Grit, 50 Pack
$12.60, RTS 400 / LS 130 Sanders, P80 Grit, 50 Pack
$6.00, ETS 125 / RO 125, P60 Grit, 10 Pack
$16.80, ETS 125 / RO 125, P40 Grit, 50 Pack
$7.20, ETS 150 / RO 150 Sanders, P100 Grit, 10 Pack
$7.20, ETS 150 / RO 150 Sanders, P120 Grit, 10 Pack
$7.20, ETS 150 / RO 150 Sanders, P60 Grit, 10 Pack
$7.20, ETS 150 / RO 150 Sanders, P80 Grit, 10 Pack
$20.40, ETS 150 / RO 150 Sanders, P40 Grit, 50 Pack
$20.40, ETS 150 / RO 150 Sanders, P80 Grit, 50 Pack
$31.20, ETS 150 / RO 150 Sanders, P100 Grit, 100 Pack
