Mr Speaker
- Jul 6, 2019
I know this is an older thread, but for someone like me that reads these now because they just now had a need for the info: As my username implies, I have some involvement with loudspeakers. And I have the SYSLITE DUO. When I started out, I too was one of those, every tripod is the same, every orbital sander is the same and the cheapest worklight will do because I was starting out and had zero budget. Not all speaker stands are equal and I now only use K&M as they are the best, more expensive but also a lt better. More stable, will last longer, more reliable. The Festool tripod is steep, and even more expensive that a K&M. It is built like a tank and has that cable management. the cable clip low is the difference between toppling the stand of just moving it over a few feet when someone trips over the wire. I have a bunch of K&M speaker stands, so I just designed and printed an adapter. But if you do not have a K&M or similar, take a deep breath and get the Festool tripod.
Compare it to why you bought the SYSLITE versus a cheaper worklight. They both give light, and it will work, but the SYSLITE is just better, better thought through. The cherry is that you will look so much more professional to your client.
