Festool ETS2 150 Battery Sander 577726
ART at WORK
Festool has just released a new Battery Sander, ETS2 Battery Sander in a 125 and 150 mm version.
They look almost identical.
Does anyone know if you can simply swap the Sanding pad from a 150 to a 125 on the same machine ?
The backing pads for the new ETSC 2 sanders are the same as the backing pads for the older ETS EC sanders so my assumption is you'll be able to swap between the 125 & the 150 paper diameters on the ETSC 2.
You'd think this would be the perfect opportunity to actively promote the inter-compatibility of both size pads, although maybe the majority of users stick to only a single size of paper?
I'd say "most likely."
But I do wonder if FTNA will talk about how it will put the sander out of balance...?
