Hans Mertens
Well then,
I needed some stuff for my new MFT/3 (will be picking that up tomorrow) so ordered a bunch of stuff from Kisling-GmbH. For those of you in Europe, they are a great shop to deal with, I've gotten free shipping on this order to Belgium, it arrived 3 days after the payment, it wasn't complete but they send the remaining stuff free of charge. And they have a great prices for the consumables and accessories.
They had the new FS-PA and FS-PA-VL in there webshop so I ordered that as well, since I recently changed jobs I'll be doing more woodworking at home and a convenient way to cut pieces at the same size repeatably was very appealing.
Order arrived last Friday but this was the first moment I had some time to take pictures and write a little preview.
Let's start with how they arrive and what's in the box...
two cardboard boxes, one for the FS-PA and one for the FS-PA-VL, nothing special, just like we're joust to getting our accessories.
The FS-PA is usable for pieces up to 650mm wide and the FS-PA-VL is usable for pieces 195mm wide and 70mm high (thick), so it's a little less then the maximum capacity of the TS75, keep an eye on this for those of you with a TS75, not a problem for me...
This is what's in the box of the FS-PA, the two profiles, two stops, a manual and a parts list
and in the FS-PA-VL box: two short profiles with bridge, two handscrews and the same manual and the same parts list as the FS-PA.
the profile, it's 59mm wide and 18mm thick, the T-slot on the top is were the stops slide in, a festool clamp will NOT fit!!! it's to small...
The FS-PA and FS-PA-VL combined, they fit together without any play and are fixed with the thumbscrews no problem there.
This is were the FS-PA connects to the rail, the two screws at the back are for adjusting the squareness of the FS-PA to the guiderail!!!
the big green screw on top is for fixing it to the guide rail together with the leveller at the underside. The screw with the slot-head at the back is for adjusting the distance of the FS-PA to the guiderail, to make sure the measurements on the FS-PA are correct. At the underside you can see that the screws (slothead and big green) are put in a long hole, they can be adjusted about 10mm.
I don't have a guide rail with me at the moment, all my stuff is at my grandparents garage because my dad works on some classic cars so our garage's are packed full...
I'll get back to you when I had a change to test it and post more pictures.
Cheers
Cheers
