Festool Green
JCLP
Would anyone know the RGB or CMYK values for Festool Green?
I found this information here on the FOG and made a little file for reference.
...oops just had to change the image
Just noticed you are in the GTA.  I was given a few weeks ago a Ben Moore tech support 1-800 from one of their stores when I was querying about what was the best primer to use which the skeleton staff at my BM in Ajax was unsure what to suggest.  I never did call them as I simply ended up going to another BM in Whitby who knew what they were doing.
Here's the number I was given which the BM rep in Ajax said is the same number he uses to get advice/direction...
1-800-361-5898
Good luck!
Thanks Peter. The CMYK values in your second post is perfect.
1-800-361-5898
Good luck!
Hi Kevin. Wanted the numbers as I wanted to use that green colour on some art work that I'm creating in Photoshop. As for best primer, I only use BM Advance Primer for everything. I apply it with Purdy's Jumbo White Dove mini roller with 1/4" nap. I found that if you use the roller sleeve once, wash it and then use it a second time on the finish coat you end up with a super smooth finish. I've been experimenting for many months trying to get that sprayed look without using a spray and I'm almost there. I also rub down the final coat with Presta Supercut compound to get a glass finish when needed.
