Festool New Template Guides for the OF 1010 - Precision Routing Made Simple
Ultimate Tools Marketing
Festool Dealer
Burnaby, BC
These items are available starting September 18. Pre-orders are recommended to reserve stock and ensure availability.
Now available for pre-order are imperial template guides for Festool's OF 1010 router. They are available in the Accessory Systainer, or individually.
Festool Accessory Kit for OF 1010
The Festool OF 1010 Accessory Kit enhances your router’s capabilities with a full range of precision tools, all neatly organized in a compact Systainer3 with custom foam inserts. It includes a guide rail adapter, trammel unit with fine adjuster, edge and transparent base runners, centering mandrel, and dust extraction accessories—perfect for straight, circular, edge, and template routing.
A Micro Systainer3 stores small parts like screws and fasteners, while the main Systainer3 has space for essential router bits. Everything is protected, easy to access, and designed to keep your workflow smooth and efficient.
Festool Imperial Template Guides for OF 1010 Router
Imperial template guides are ideal for use with imperial-sized router bits, so offsets are simple to calculate and don't require conversions. These sturdy steel guides bolt to the base of the router for secure positioning and repeatable templating - perfect for precision routing of inlays, recesses, and other fine work.
Available in five sizes:
  • 3/8"
  • 1/2"
  • 5/8"
  • 3/4"
  • 1"
Shop All New Festool
