arso_bg
- Jan 6, 2008
Festool OF 1400 gradually falling down in a CMS-VL MFT/3 router table while cutting box joints
I own the router table for some 6 year or even more. This is for the first time that I experience such a result. For cutting the joints this time I use an Incra I-box
Here are two pictures illustrating the story. The reason for what you see is that after I set the proper dept of cut and start cutting the joint the router is falling down and when I finish to cut the router bit is almost 8 mm down! There is no lock feature with this router table
Did someone else have similar experience?
Any ideas how to handle the problem?
