martinsulistio
- Nov 21, 2015
Hi everyone. I have 2 questions.
1. I tried to drive a lag bolt (high torque, low speed) and I heard a loud SNAP coming from what I suspect the clutch (regular clutch for hex head). What happens then, the clutch won't open and my bit was left. A day later I tried to open it and there was no problem. What do you suppose happened?
2. I tried to make a hole using a 13mm spade bit into a 3cm stock, using max speed and max torque. Apparently it's not strong enough. Is this acceptable/ normal?
