Festool Polishes and release agent
sdppm
I was watching a video on polishing lacquer and between the 800, 1000 and 1200 grit sanding he used what he called a release agent to clean the work between grits. I can't find it anywhere. was he using a festool release agent item or was it some kind of generic item. I don't know what he was using. Anyone that polish's lacquer do you know what he is referring to when he says hes using a release agent.
Polishing video referred to
Thanks for the help
I'd suggest that you mix up a 50/50 batch of denatured alcohol and filtered water as a "release agent", and put it in a spray bottle.  The alcohol acts as a solvent and the mixture dries more quickly that water only.  It's also good for cleaning solid surface material.
I thought this was asked before and the release agent was a mystical solution called h2o
