markorjack
- May 14, 2012
I have recently ordered a swag of Festool gear including the MFT-3 and associated clamps.
Sitting in my workshop is all the Benchcrafted hardware required to build a split top Roubo workbench.
My current workbench utilises Veritas round dogs and wonder pups, as well as Gramercy holdfasts.
Another two holdfasts are part of the Benchcrafted Roubo kit so I now have 4.
All of these are 3/4".
Is anybody using similar equipment and switching between the MFT and a workbench?
Will the 3/4" gear work on the MFT, or more importantly with a 20mm hole.
If so I will make the dog holes on my Roubo 20mm so they work with the Festool clamps, Qwas dogs etc but so I can still use my existing equipment.
I realise the thickness of a workbench top will preclude the use of some clamps, but dogs etc should be fine.
After my Roubo top is assembled I will more than likely mill the holes using CNC.
I could even match the spacings to the MFT, as I plan to do with a full sheet out feed table I am constructing for my table saw.
Cheers, Jack
Cheers, Jack
