Hello all,
I'm planning to purchase a Festool router and would greatly appreciate some help deciding on a router and a minimal set of bits and accessories.
I'm hobbyist building simple things out of plywood. I do NOT have a router table and intend to do most things with tracks (have TS55+MFT+CT Mini and love them), templates, or freehand.
Specifically, I want to:
- Right-angle join 18mm birch ply to 18mm birch ply using dados and rabbets
- Cut grooves for 9mm birch ply drawer bottoms
- Template-cut handle openings in drawer faces (like Paulk mobile workshop drawer handles)
- Put a small but comfortable to touch roundover on solid wood faces
I *think* I can use the following:
OF 1010
#490980 HW Spi S8 D10/30 Spiral cutter (double pass 18mm dados and rabbets to fit, single pass 10mm grooves for 9mm bottoms)
#484176 KR-D 13,8/OF 900 Copying ring (for template cutting with the D10/30 spiral cutter)
#491010 HW S8 D19,1/R3 KL Roundover
Some questions:
(1) Is the OF1010 powerful enough to do what I want comfortably?
(2) Is an 18mm spiral cutter a more efficient way to cut dados etc. for 18mm ply?
(3) Is 10mm groove for 9mm drawer bottoms about right -- not too loose?
(4) Can you use a 10mm spiral cutter with a copying ring that has a 10mm internal diameter (or do I need a larger ring)?
(5) Any other bits or accessories that better match my goals?
Thanks very much for any guidance!
Cheers,
OF 1010
Some questions:
Cheers,
