usernumber1 said:can the TSO guides be used for repetitive short cuts like with the festool extensions?
how do you measure if you want the cut from the off-side?
edit: the only video i can find of them in use is by the poplar shop. it's comical how he craps on the festool ones like a bad infomercial.
what i find interesting is that he doesn't seem to actually use both TSO tracks. looks like i can just use one as you're just referencing with the edge guide anyway.
DynaGlide said:For thin rips, get a small table saw. It will make life a lot easier than trying to use any parallel guides.
DynaGlide said:When I said thin rip I should have said narrow rips, i.e. narrower than the width of the guide rail. The guide rail does not have enough support so you get into weird situations of trying to place another piece of material the exact same thickness under the rail and hoping it doesn't skew your cut.
