R
Rob Z
Guest
I just noticed that Steve asked his question a long time ago and likely has solved his problem by now [big grin]. But in case it helps someone else, I have grabbed a bit in a situation like this with a spring clamp. With the rubber tips padding the contact with bit there is no risk of damaging the carbide, and it's easy to pull the bit out of the hole it's in.
