flappy riving knife
russ_1380
Hi guys, just a quick one.
I was having a bit of trouble with my TS 55.  When inspecting it closer I have found the riving knife has some lateral play and feels floppy.  I doubt this is causing the problem but would like to know if it needs some adjustment whilst I'm giving it a once over.
Is this normal?
Cheers
Russ
Is this normal?
No. Lock the blade down as if you are going to change it. You will see a socket cap screw that locks the riving knife you should check it is probably loose. It uses the same Alen key as does the blade.
Details on page 9 of Rick's Manual
http://www.bobmarinosbesttools.com/docs/TS_55_EQ_US.pdf
