Birdhunter
- Jun 16, 2012
I had. 18” by 9” by 1” slab of highly figured wood I needed for a small table. Unfortunately, it was slightly twisted. My jointer is 8” so I couldn’t use it. I could have hand planed it, but was feeling lazy.
I cut two 3/8 plywood strips each 18” by 1 1/2” wide. I put the slab on my table saw top and glued the plywood strips to the sides of the slab making sure the strips were flush with the table saw top. The strips stood proud of the slab’s surface by 1/2” like runners on a sled.
I then ran the slab with the “runners” down through the planer. What emerged was a perfectly flat surface with no twist.
I cut off the runners and ran the slab back through the planer. I now had a flat slab with two parallel surfaces.
